chewy75
Dec 11, 2024Tutor
Cm600 connection issues xfinity
I've been having connection issues with modem on and off for about 6 months. It usually happens when my router, or modem loses power and starts back up. My router is a asus RT-AX86U Pro running asuswr...
- Dec 13, 2024So xfinity tech came out today and traced my coaxial cable back to a splitter. My apartment complex is old and the splitter was hidden. To make it worse, the previous tenants set it up with the input/output cables reversed. That combined with my older modem is what was causing the issues. The tech removed the splitter and my old router is now able to connect to 4 Upstream channels.
I'm also getting a new modem this weekend and went with a surfboard sb8200.
Thanks everyone for the help and input. It's much appreciated. Happy Holidays
Dec 11, 2024Guru - Experienced User
Cable Connections data is good.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
The CM600 is of older model so you may need to upgrade the modem at some point.
