chewy75
Dec 11, 2024Tutor
Cm600 connection issues xfinity
I've been having connection issues with modem on and off for about 6 months. It usually happens when my router, or modem loses power and starts back up. My router is a asus RT-AX86U Pro running asuswr...
- Dec 13, 2024So xfinity tech came out today and traced my coaxial cable back to a splitter. My apartment complex is old and the splitter was hidden. To make it worse, the previous tenants set it up with the input/output cables reversed. That combined with my older modem is what was causing the issues. The tech removed the splitter and my old router is now able to connect to 4 Upstream channels.
I'm also getting a new modem this weekend and went with a surfboard sb8200.
Thanks everyone for the help and input. It's much appreciated. Happy Holidays
chewy75
Dec 11, 2024Tutor
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 459000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 5 | 459000000 Hz | -0.1 dBmV | 42.5 dB | 0 | 0 |
| 2 | Locked | QAM256 | 22 | 561000000 Hz | 0.3 dBmV | 41.9 dB | 0 | 0 |
| 3 | Locked | QAM256 | 23 | 567000000 Hz | 0.4 dBmV | 42.1 dB | 0 | 0 |
| 4 | Locked | QAM256 | 24 | 573000000 Hz | 0.6 dBmV | 42.2 dB | 1 | 0 |
| 5 | Locked | QAM256 | 1 | 435000000 Hz | 0.4 dBmV | 42.4 dB | 0 | 0 |
| 6 | Locked | QAM256 | 2 | 441000000 Hz | -0.1 dBmV | 42.0 dB | 0 | 0 |
| 7 | Locked | QAM256 | 3 | 447000000 Hz | -0.7 dBmV | 41.8 dB | 0 | 0 |
| 8 | Locked | QAM256 | 4 | 453000000 Hz | 0.6 dBmV | 42.9 dB | 0 | 0 |
| 9 | Locked | QAM256 | 6 | 465000000 Hz | 0.4 dBmV | 42.8 dB | 0 | 0 |
| 10 | Locked | QAM256 | 7 | 471000000 Hz | 0.6 dBmV | 42.8 dB | 0 | 0 |
| 11 | Locked | QAM256 | 8 | 477000000 Hz | -0.4 dBmV | 42.0 dB | 0 | 0 |
| 12 | Locked | QAM256 | 9 | 483000000 Hz | 0.6 dBmV | 42.6 dB | 0 | 0 |
| 13 | Locked | QAM256 | 10 | 489000000 Hz | 0.1 dBmV | 42.3 dB | 0 | 0 |
| 14 | Locked | QAM256 | 11 | 495000000 Hz | -0.1 dBmV | 42.4 dB | 0 | 0 |
| 15 | Locked | QAM256 | 12 | 501000000 Hz | 0.7 dBmV | 43.0 dB | 0 | 0 |
| 16 | Locked | QAM256 | 13 | 507000000 Hz | 0.3 dBmV | 38.6 dB | 0 | 0 |
| 17 | Locked | QAM256 | 14 | 513000000 Hz | -0.4 dBmV | 42.4 dB | 0 | 0 |
| 18 | Locked | QAM256 | 15 | 519000000 Hz | -0.5 dBmV | 42.0 dB | 0 | 0 |
| 19 | Locked | QAM256 | 16 | 525000000 Hz | -1.0 dBmV | 41.9 dB | 0 | 0 |
| 20 | Locked | QAM256 | 17 | 531000000 Hz | -0.4 dBmV | 41.9 dB | 0 | 0 |
| 21 | Locked | QAM256 | 18 | 537000000 Hz | -0.6 dBmV | 41.9 dB | 0 | 0 |
| 22 | Locked | QAM256 | 19 | 543000000 Hz | -0.5 dBmV | 41.8 dB | 0 | 0 |
| 23 | Locked | QAM256 | 20 | 549000000 Hz | -0.1 dBmV | 41.9 dB | 0 | 0 |
| 24 | Locked | QAM256 | 21 | 555000000 Hz | -0.3 dBmV | 41.9 dB | 1 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 3 | 5120 Ksym/sec | 22800000 Hz | 57.0 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 3 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 4 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
chewy75
Dec 13, 2024Tutor
- plemansDec 14, 2024Guru - Experienced User
Glad you got it resolved!
