brian66
Jun 10, 2019Aspirant
cm600 doesn't stay connected to internet once xbox is turned off, needs reboot every time
my xbox is plugged directly to modem. Once i shut it off and turn it on later there is no internet connection. I have to unplug it, sometimes several times to establish a connection. The same ting ha...
antinode
Jun 10, 2019Guru
> my xbox is plugged directly to modem. [...]
Without a (NAT) router? Is the Xbox the only device which is ever
connected to the modem, or are you trying to connect multiple devices to
it without a (NAT) router?
> [...] i tested my son's computer. [...]
After disconnecting the Xbox?
What, exactly, are you connecting to what, exactly, when, exactly?
- brian66Jun 10, 2019AspirantI am only using an xbox x directly to the cm600. I tried on an occasion to plug son's computer to see if there was any difference. There wasn't.
I play almost every night. When I turn on the xbox it doesn't have internet access unless I power cycle the modem. The modem is always on and plugged in unless I am power cycling it after turning xbox on. Only a few times in the last 3 months was the xbox connected when I turned it on. My original modem and the new replacement have the same problem. It's not my connection or internet because a artis 6190 stays connected all the time. I just want this thing to work. Cm600 - brian66Jun 13, 2019Aspirant
Does anyone have a suggestion?
