Ksutt
Jul 26, 2020Initiate
Cm600 drops signal (or reboots) ALL THE TIME, every day
Attached a screenshot of its behavior this morning, but have no clue what I'm reading! I've restarted it countless times, did a factory reset yesterday. I do use its included power supply. It's only ...
Jul 26, 2020Guru - Experienced User
do you also have a screen snip of the cable connections page?
Your errors tend to be line errors but the cable connections page can help.
also, if you have any splitters, attenuators, amplifiers connected to the coax line, remove them. preferably, move the modem to right where the coax enters the home and direct connect it. this prevents wiring ran in the walls from being the issue.
Ksutt
Thank you! I just removed the outside splitter and used a coupler instead to get the modem directly to the outside coax, and it's been working seemingly normal again ever since! But fingers-crossed, it's only been an hour. I guess if it starts acting up again I'll have to get a Spectrum tech out here to switch out the wires...
