Sca555
Sep 20, 2020Aspirant
Cm600 errors
I have Spectrum and my internet has been acting up for a while now and decided to check my logs and I saw these events. I'm not very knowledgeable in this area.
Sca555
Sep 24, 2020Aspirant
I called them and they said there's nothing wrong on their end. Low speeds.
Sep 24, 2020Guru - Experienced User
What speed are you getting directly from the modem? without a router attached.
so modem----pc/laptop
what speed?
what website are you testing with?
- Sca555Sep 24, 2020AspirantI have eero pro. It's test shows me 960 mbps so I believe it's testing from the modem but I'm only getting 300-400 mbps with independent speed tests such as spectrum.com speed test. Fast.com only shows 150 mbps. No computer to do line test with.
- plemansSep 24, 2020Guru - Experienced User
If eero is showing full speed, then its what's limiting it. The fact that its own hosted speedtest (directly off the eero itself) is hitting full speeds means the modems working right.
not the modem.
Again, for a true test of the modem, hardwire a pc/laptop to it. Not with a router in between because it can limit speeds.
Plus testing over wireless isnt going to hit gig speeds. or even close to it.
