kautto
Jul 26, 2018Aspirant
CM600 firmware downgrade when switching ISPs?
I have a CM600 that I was using with Spectrum. As part of having their service, they obviously pushed a firmware update, which locked the modem into IPV6-only mode. My new ISP (WOW) does not support ...
vkdelta
Jul 27, 2018NETGEAR Employee Retired
Cable Operators have strictly specified that once the MDD IP mode has been, it should be locked and cannot be modified by the end-user.this is requirement from ISPs vendors have to follow.
kautto
Jul 30, 2018Aspirant
Hi vkdelta, thanks for the response! I realize that it's apparently standard for them to push the updates. My question is, how do I get my cable modem back in working conditions, so I can use it with my new ISP? After all, it's my cable modem, not the ISPs, and it isn't written anywhere that it's a single-use device that gets thrown away if you dare switch away from a service provider.. is it something Netgear can reset in the modem?
