TonyinCNY
Mar 06, 2017Star
CM600 firmware not upgraded by Time Warner Cable
I wanted to upgrade the existing firmware (V1.01.05) of my cable modem (CM600). Netgear website says that for Time Warner Cable (TWC) I should have V1.01.12 and that I cannot upgrade manually. I h...
DarrenM
Mar 08, 2017Sr. NETGEAR Moderator
Hello TonyinCNY
It is pushed out by the ISP I would call tech support and ask for the higher modem support typically they call it L3 they will know more about this.
DarrenM
Jryan619
Jul 28, 2017Star
Do t listen to the guy saying they will push it out. You have version 5, that router is up to version 13. It will work up to 1000mbps, and than it turns into toast if you get 300Mbps service.
