Retired_Member's avatar
Retired_Member
Dec 22, 2017
CM600 High Speed Cable Modem need to change the LAN setting to bridged
I added Norton Core and it wants control of services, I need to get into settings and change LAN to bridge mode. Can't access web over wireless now. So need best solution to fix this.
1 Reply
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    Cm600 is "bridged modem". It does not do any routing.
    you will need to either correct directly to your modem or fix your router.
