surge50
Jun 22, 2017Aspirant
CM600 modem help with firmware
I have Mediacom and contacted them to upgrade my firmware per Netgear website. Mediacom advised that they do not have any firmware upgrade and to contact Neatgear. Please help.
DarrenM
Jun 26, 2017Sr. NETGEAR Moderator
Hello Surge50
No way to do a manual upgrade of a cable modem if a firmware update is available it would be pushed out via the ISP.
DarrenM
Jryan619
Jul 28, 2017Star
Well that is real nice, is it it. Now I have to go wast tomorrow going back to frys returning all my net gear stuff. That shouldn't be illegal for you to sell something and not tell the consumer - but I will be telling everyone I know. I bought your Cm600 so I wouldn't have to rent one from Time Warmer. You say it's compatible, but the one I just bought from the store was so whacked it could only get on line at 15Mbps, and I average 300. Tried resetting, sending new signals, and than Tim Warner Spectrum says they cannot give me a firmware or software update because I own the device. They will occasionally send out signals to tweak things, but if you buy your own there's nothing they can do for you homie. I heard the same thing at Netgear, there's nothing they can do for me, so I guess I won't have nothing to do with you. I did just buy the Netgear Orbi RBR50/RBS50 2 pack, along with a Netgear hub that was $28. I guess I won't need any off that, because they did offer me a modem/router that is high speed, designed for their network, AC3200, free for a year, and than only five bucks a month after that. That is the only good thing about Charter taking over, TW used to charge $10 per month for the modem, and another $15 on top of that for using their wireless. They said $5 is now their regular price, so everyone might as well get their stuff they update. They also said if I have any dead spots they provide the enhancers at no extra charge. Tomorrow I will be returning $450 worth of your product to the store for your horrible policy of not giving updates.
- DarrenMJul 31, 2017Sr. NETGEAR Moderator
Hello Jryan619
You have alot of T3 timeouts in the logs this is typically a line issues either in the wiring in your home or outside you may want to have a tech from your ISP come out and check the lines.
DarrenM
