R2858
Jul 09, 2019Follower
CM600 modem
I’m interested in buying a CM 600 modem. I’ve read an online guide that says I need to connect it to a computer during the initial setup process. However, I only own a Mac computer without an Etherne...
Jul 09, 2019Guru - Experienced User
There is USB to Ethernet adapters that you can connect to Macs with out LAN ports.
You can try connecting a router to the modem however you'll need to contact your ISP to have them help you get the modem associated with there system. Having the router connected between the modem and your Mac may not work.
