Pkdan1
Oct 04, 2022Tutor
CM600 Please check RF connection
Hi, I have a CM600 that suddenly stopped working. When i log into the modem it says “your modem is offline please check the RF connection”. I called xfinity and they said everything is good on thei...
- Oct 12, 2022It turns out my neighbors dog bite my line… xfinity was able to run a new line and everything is fix now. Thanks for the help!
Oct 05, 2022Guru - Experienced User
Yes, if you're at -20dbmv, you have a line issue.
Move the modem right where the coax comes into the home and direct connect it.
See if that works. If it doesn't, then its something exterior to the home causing the issue and the isp needs to come check the line.
If it connects, post a screensnip of that cable connections page. It'll let us see how the incoming signal is and if its something interior to the home you need to work on or if the signal is still poor.
