bubujove
Oct 04, 2023Aspirant
CM600 possible faulty firmware update?
Back in July, my internet usage at home spiked to from a typical 200 GB per month to 1.2 TB (resulting in fees) with no change in usage. I contacted my ISP (Xfinity) and they said it could be a faulty...
bubujove
Oct 11, 2023Aspirant
Thanks for your reply.
Are you saying that it is not possible for a faulty firmware update to make repeated requests in error or are you saying that it is not possible to see logs from the modem?
While I certainly believe that it is not the modem, I would like to be able to check and verfiy. I would like to know
1) was a firmware update issued (where can I find this information)?
2) are there logs I can see on the modem itself?
3) do these modems automatically update themselves? I think there is a good chance that they do not, but, again, I don’t know. Xfinity may simply be mistaken in believing that the modem I am using is one of their own.
Thanks for your help.
Oct 11, 2023Guru - Experienced User
The firmware is part of the provisioning from the ISP. The ISP pushes any firmware/updates automatically.
Not saying it can't be bad (see the CAX30 fiasco) but its pretty thoroughly tested.
And not saying something internally can't be wrong in the modem. Thats always a potential. it's just not something that I've seen on here and I've been on here a while. It tends to be something else causing increased data usage.
