demonick
Dec 22, 2023Aspirant
CM600 replacement with CM1100 under Xfinity
I will be replacing my current CM600 running at 400Gbps on Xfinity's 800Gbps service with a CM1100 to get the full 800Gbps full bandwidth. It has been a long time since I installed the CM600 and my n...
- Dec 22, 2023
xfinity does need to add it to their system but you can use their xfinity app to upgrade the modem. Pretty easy to do
Dec 22, 2023Guru - Experienced User
- demonickDec 22, 2023AspirantThank you. Can I do it from a laptop on the Xfinity website? I must say, this is THE MOST responsive user forum I've ever participated in.
- plemansDec 22, 2023Guru - Experienced User
Sadly, no you can't. You used to be able to but Comcast pulled that functionality.
You could do it through xfinity's chat but installing the app to activate and then uninstalling it is still faster than dealing with xfinity
