Kcer's avatar
Kcer
CM600 speed
Just upgraded to the CM600 modem, but whenever I do speed tests the download is 15 or so, upload less than 2, ping varies a lot.  The CM600 is capable of a lot faster speeds than that!  Overall we're accessing web pages faster than with the old modem, but why are the speed tests so abysmal?  We have Xfinity internet.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Are you doing speed tests directly from the modem or are you connected to a router? Try direct from the modem.
    DarrenM
    • Kcer's avatar
      Kcer
      Connected to a router.  However, I contacted Xfinity and they upgraded us to a much faster internet plan.  They had SAID on our bill that we were paying for 70 mbps, but the agent SAID we only had the basic plan with 6 mbps.  That's Xfinity for you.  Now the speed tests are much much faster.  Not noticing much actual difference though, so we may have to replace our 5-year-old computer.  Thanks for your input, Darren.
