jrhockin's avatar
jrhockin
CM600 upload light turns amber
Model CM600 Just did a factory reset. Maybe that will solve the prolem that the UPLOAD LIGHT turns amber after a while. Also, before I did the reset, the modem would just not work and lights flash....
