erricz
Nov 19, 2019Aspirant
CM600 WAN port will not connect at 1000
CM600 Hardware Version 1.01B Firmware Version V1.01.18 Very recently I started getting slow download speeds (10MB/s vs 50MB/s on Steam). Opened a ticket with Comcast, they've had multiple tech...
- Nov 19, 2019
Has a power OFF for 30 seconds from the wall outlet then plugged back in do anything?
And your PCs networking adapter supports 1000Mbps as well? If so, sounds like the CM maybe faulty on the WAN port.
Nov 19, 2019Guru - Experienced User
erricz
Yes, sir, my PC connects to my switch and router at 1G (both Netgear, I might add).
I connected the CM to my Gig switch and it would only grab 100M as well. So, yeah, I kinda assume the port went bad too. Shame as it would only be 2 years old in January. This has to be my shortest lived Netgear device ever. I ended up ordering a CM700 from Amazon with a 4-year add-on warranty. Not gonna get me again.
Thanks for the reply!
- FURRYe38Nov 20, 2019Guru - Experienced User
Ok glad a new modem is on the way.
Enjoy.
