erricz's avatar
erricz
CM600 WAN port will only negotiate 100M/Full
CM600  Hardware Version 1.01B Firmware Version V1.01.18   Very recently I started getting slow download speeds (10MB/s vs 50MB/s on Steam). Opened a ticket with Comcast, they've had multiple tech...
  • FURRYe38's avatar
    Nov 21, 2019
    IF the modems been reset and you've tired different cables. Sounds like the WAN port is faulty and the modem probably needs to be replaced.
