greeno
Oct 09, 2023Apprentice
cm600 won't negotiate 800down/100up
hi, gear: cm600, firmware V1.01.22, latest approved by xfinity. router is ubiquiti ER-X (1gig cable aggregate). xfinity super fast, 800down/100up, purchased plan. we just went from a triple play ...
greeno
I just order the cm1100.
It’s still annoying that they’ve essentially blacklisted my cm600 so they it can’t be provisioned to 400/100.
greeno
i'm in a similar situation with a CM600. the modem is locked to a 400mbps down/ 20mbps up profile and cannot be re-provisitioned to the 800/100 i pay for. CM600 is docsis 3.0. to get the profile/speed i pay for i have to upgrade to a docsis 3.1 model. just purchased a CM1100.
best,
jeff
- plemansOct 14, 2023Guru - Experienced User
Hope it works well for you!
- greenoOct 14, 2023Apprentice
Comcast tech came out. First informed me that only their modem and some hitrons will give more than 25mbps up. Comcast locks it at this. Vendors and Comcast have not agreed on a spec for the upstream bonding.
We verified at the modem I’m getting more than 800mbps down. At the router I’m getting have that. The switch in the edgerouter-x is cutting the bandwidth.
I dropped in openwrt and that removed the switch overhead.
So we wait for netgear and comcast to agree on the upstream spec.
Best,
Jeff- plemansOct 14, 2023Guru - Experienced User
Crapcast tech's are known to be FOSs. I've got a CM1100 and hit 40 Mbps with it. No problem at all. So the 25mbps is bs.
They're slowly rolling out increased upload speeds.
but with what he said, I'd be suspicious of anything else he/she said to you.
