demonick
Nov 26, 2023Aspirant
CM600 won't negotiate 800down/100up
Thank you!
I am experiencing the exact same issues as the OP. Xfinity, an 800 Mbps upgrade activation, and just seeing 400/24 Mbps. Ordered a CM1100.
After Xfinity installed the boot file...
demonick
Dec 11, 2023Aspirant
Doh!. No. Just pressed the button. Forgot the process. Thanks.
Will the proper reset process wipe the current boot file and reinstall the original default as it came from the factory? If so, I believe this would require an Xfinity reactivation.
Dec 12, 2023Guru - Experienced User
No.
