Gael94
Feb 12, 2020Aspirant
CM600 Xfinity: Modem Access Denied
I purchased the CM600 to pair with our Xfinity service The setup was easy and everything is working I attempted to access the CM600 settings with the default "admin and password" credentials ...
Gael94
Thank you for the response
At one point do I reattach the coax?
Will the "reset" affect connection to Xfinity?
Feb 12, 2020Guru - Experienced User
Can reattach if you gain access.
It only resets the modem and and connection to the service. The modem will get a new IP address possibly and thats it.
