greeno
Apr 27, 2019Apprentice
cm600 xfinity T3 error then bufferbloat
Hi,
i have blast pro (250down/10up) with xfinity in 94550. the cm600, firmware version shows V1.01.18, is connected to a ubiquiti edgerouter-x running latest 1.10.9 firmware. i use the smart que...
greeno
there's a splitter infront of the cm600 to feed the xfinity digital voice. i've removed that splitter and the levels are instantly better:
| <tabindex=-1>Downstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Upstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
i'm not sure what to do about this... so next text is disconnect the voice modem and reintroduce the splitter...
Apr 27, 2019Guru - Experienced User
Is this at the point where it enters the house?
- greenoApr 27, 2019Apprentice
yep. it's a 1682g. i think there's a etma only modem that's approved by xfinity. might that help?
- plemansApr 27, 2019Guru - Experienced User
I would have to believe after seeing all this info that the modem is fine and its the signal coming in. If that's right where it comes into the housee, I'd contact xfinity (if thats who you use) and have a discussion about power/signal levels and having them check it.
thanks. i'll post back...
