NickGobeli
Oct 11, 2022Aspirant
CM600/CM1000 no ethernet
I have a CM600 modem with a AC1750 router, out of the blue I have no connection, the ethernet light on the CM600 is not lit, all other lights are on, tried plugging directly into the modem with my la...
Oct 11, 2022Guru - Experienced User
CHeck the ethernet adapter on your PC or ethernet jack on the router for troubles.
Swap LAN cables between the modem and router. CAT6 is recommended.
What is the brand and model# of the wifi router you have connected to the modem? Contact the Mfr of this router for additional help and information regarding there product.
- NickGobeliOct 11, 2022Aspirant
I swapped cables and nothing. The router is a Netgear Nighthawk AC1750
- FURRYe38Oct 11, 2022Guru - Experienced User
Is there a R#### model number? AC1750 is a combined wireless speed.
Check to make sure this model router has 1000Mpbs supporting WAN port. Some older model routers only supported 100Mpbs.
Its an R6700, should be good to 1300Mbps.
