aestevezus
Jan 22, 2022Follower
CM700 - Intermittent disconnects, reboot fixes it (errors in log)
Hi Netgear community, Hoping you folks could shed some insight for a problem I've been having lately. As of the last few weeks I've experienced my internet going down at random intervals. So far...
Jan 22, 2022Guru - Experienced User
You've got a lot of power notices in your logs.
You'll want to check your line.
Remove any splitters, amplifiers, or signal attenuators from you line.
Check the line for damage, kinks, old/bad/cheap connectors and remove them if you do.
Preferably move the modem to right where the coax comes into the home.
If that doesn't help and you're still getting the dynamic range window violations, then the ISP would need to check the line.
It could be the modem but not usually when you have those errors
