Ev10ss
Jan 15, 2020Aspirant
cm700 and slow upload speeds
subscribed to Mediacom for 200 Mb service (200 download and 20 upload) I work from home so I need a stable connection. Last Friday my upload basically quit with the download stayed at about 200 Mb....
- Jan 20, 2020Finally broke down and installed a new router last Sunday. Internet has been steady ever since. Orbi was only 7 months old.
Jan 17, 2020Guru - Experienced User
Try a factory reset on the Orbi system and setup from scratch.
Good Luck.
Ev10ss
Jan 20, 2020Aspirant
- FURRYe38Jan 20, 2020Guru - Experienced User
So it was the Orbi or what did you install?
- Ev10ssJan 21, 2020AspirantI decided to try a goggle router and two remotes. When functioning Orbi was superior. Miss the ports on the remotes. So far internet is stable and signal is strong. Needed to move quickly as I work from home. Plan to work with customer support and use (hopefully) replacement as backup
- FURRYe38Jan 21, 2020Guru - Experienced User
Ask for an RMA on the Orbi. Probable faulty system.
v2.5.1.8 FW for the 50 series is good.
Good Luck.
