jortease
Aug 05, 2020Aspirant
CM700 compatibility with Xfinity 600mbps
Bought the CM700 modem to use for my Xfinity 300mbps speed plan. It works great, i get at least 300mbps wired directly to my own router. Recently i decided to increase my plan speed to 600mbps and no...
Aug 05, 2020Guru - Experienced User
Be sure to power OFF the modem for 1 minute them back ON.
Be sure to have the ISP re-send the configuration file to the modem.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
- Derrickh29Aug 06, 2020AspirantI am having the same issue and there is a splitter there, I bet it is causing issues!
Why does it create issues and what would do in a similar situa?- FURRYe38Aug 07, 2020Guru - Experienced User
Be sure there are no coax cable line splitters in the between the modem and ISP service box. Splitters can cause a reduction of line signal levels to the modem or induce noise on th line as well.
