Kira757
Aug 15, 2020Follower
CM700 Download Speeds
I am currently using a CM700 Modem along with a Netgear AC1750 dual band router. I am currently getting between 200-300 MBPS speeds when I should be getting closer to 1000. Comcast ran checks on thei...
Aug 17, 2020Guru - Experienced User
Are you speed testing with a wired PC connected directly to the back of the CM modem with out the NG router being online?
What is the model# of the NG router? R####?
