Osirus
Oct 08, 2020Aspirant
CM700 Downstream Light blinking
Purchased a new CM700 and activated (via online) with Comcast. Before I had Arris SB6580 and had download speed of >150 mpbs, now I am getting <90 mpbs with blinking download stream light. Here is ...
Osirus
I am not sure what you mean by a "screen snip of the cable connections page."
With regards to other devices, I do not have any splitters, amplifiers, or attenuators.
I will try to replace the coaxial cable and see if that helps.
Thanks for your suggestions.
Osirus
If you mean this...
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 663000000 Hz | Locked |
| Connectivity State | Ok | Operational |
| Boot State | Ok | Operational |
| Security | Enabled | BPI+ |
| IP Provisioning Mode | Honor MDD | honorMdd(4) |
Downstream Bonded Channels (Partial Service)
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | UnCorrectables |
| 1 | Locked | QAM 256 | 26 | 555000000 Hz | -17.3 dBmV | 30.0 dB | 22769409 | 5169734 |
| 2 | Locked | QAM 256 | 27 | 561000000 Hz | -10.7 dBmV | 33.4 dB | 5312 | 2128 |
| 3 | Locked | QAM 256 | 28 | 567000000 Hz | -8.5 dBmV | 35.0 dB | 18 | 0 |
| 4 | Locked | QAM 256 | 29 | 573000000 Hz | -7.7 dBmV | 30.5 dB | 26287 | 0 |
| 5 | Locked | QAM 256 | 30 | 579000000 Hz | -7.5 dBmV | 31.6 dB | 3541 | 0 |
| 6 | Locked | QAM 256 | 31 | 585000000 Hz | -7.0 dBmV | 27.8 dB | 53227437 | 4307073 |
| 7 | Locked | QAM 256 | 32 | 591000000 Hz | -7.2 dBmV | 31.9 dB | 35 | 1 |
| 8 | Locked | QAM 256 | 33 | 597000000 Hz | -7.0 dBmV | 33.0 dB | 32 | 0 |
| 9 | Locked | QAM 256 | 34 | 603000000 Hz | -6.4 dBmV | 33.4 dB | 11 | 0 |
| 10 | Locked | QAM 256 | 35 | 609000000 Hz | -6.4 dBmV | 34.9 dB | 6 | 1 |
| 11 | Locked | QAM 256 | 36 | 615000000 Hz | -6.4 dBmV | 34.9 dB | 30 | 0 |
| 12 | Locked | QAM 256 | 37 | 621000000 Hz | -5.7 dBmV | 34.9 dB | 8 | 0 |
| 13 | Locked | QAM 256 | 38 | 627000000 Hz | -6.0 dBmV | 35.0 dB | 21 | 0 |
| 14 | Locked | QAM 256 | 39 | 633000000 Hz | -5.7 dBmV | 35.1 dB | 6 | 0 |
| 15 | Locked | QAM 256 | 40 | 639000000 Hz | -6.2 dBmV | 34.9 dB | 3 | 0 |
| 16 | Locked | QAM 256 | 41 | 645000000 Hz | -6.0 dBmV | 34.9 dB | 5 | 0 |
| 17 | Locked | QAM 256 | 42 | 651000000 Hz | -6.2 dBmV | 34.5 dB | 35 | 0 |
| 18 | Locked | QAM 256 | 43 | 657000000 Hz | -6.2 dBmV | 34.9 dB | 0 | 0 |
| 19 | Locked | QAM 256 | 44 | 663000000 Hz | -6.4 dBmV | 34.4 dB | 2 | 0 |
| 20 | Locked | QAM 256 | 45 | 669000000 Hz | -6.2 dBmV | 34.8 dB | 2 | 0 |
| 21 | Locked | QAM 256 | 46 | 675000000 Hz | -6.2 dBmV | 34.8 dB | 6 | 0 |
| 22 | Locked | QAM 256 | 47 | 681000000 Hz | -5.7 dBmV | 34.8 dB | 11 | 0 |
| 23 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 24 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 25 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 26 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 27 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 28 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 29 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 30 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 31 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 32 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
Upstream Bonded Channels
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 16400000 Hz | 43.5 dBmV |
| 2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 22800000 Hz | 44.3 dBmV |
| 3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 29200000 Hz | 44.8 dBmV |
| 4 | Locked | ATDMA | 4 | 5120 Ksym/sec | 35600000 Hz | 45.0 dBmV |
| 5 | Locked | ATDMA | 5 | 1280 Ksym/sec | 39600000 Hz | 42.3 dBmV |
| 6 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
- plemansOct 09, 2020Guru - Experienced User
You need to get your line checked. You have errors in the line, power levels out of spec, and unlocked channels. All signs the isp needs to check the lines.
- OsirusOct 09, 2020Aspirant
In case you are wondering here is the status after the technician fixed the outside cable line...
<tabindex=-1>Startup Procedure</tabindex=-1> Procedure Status Comment Acquire Downstream Channel 681000000 Hz Locked Connectivity State Ok Operational Boot State Ok Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables 1 Locked QAM 256 16 489000000 Hz 2.0 dBmV 35.0 dB 7 0 2 Locked QAM 256 17 495000000 Hz 1.7 dBmV 34.9 dB 0 0 3 Locked QAM 256 18 507000000 Hz 1.5 dBmV 34.3 dB 1 0 4 Locked QAM 256 19 513000000 Hz 1.9 dBmV 35.0 dB 0 0 5 Locked QAM 256 20 519000000 Hz 1.4 dBmV 35.0 dB 0 0 6 Locked QAM 256 21 525000000 Hz 1.5 dBmV 35.0 dB 13 0 7 Locked QAM 256 22 531000000 Hz 1.5 dBmV 34.9 dB 0 0 8 Locked QAM 256 23 537000000 Hz 1.5 dBmV 34.3 dB 0 0 9 Locked QAM 256 24 543000000 Hz 1.9 dBmV 34.9 dB 0 0 10 Locked QAM 256 25 549000000 Hz 1.4 dBmV 34.4 dB 0 0 11 Locked QAM 256 26 555000000 Hz 1.5 dBmV 34.3 dB 0 0 12 Locked QAM 256 27 561000000 Hz 1.5 dBmV 35.0 dB 0 0 13 Locked QAM 256 28 567000000 Hz 1.2 dBmV 34.9 dB 1 0 14 Locked QAM 256 29 573000000 Hz 1.7 dBmV 33.7 dB 0 0 15 Locked QAM 256 30 579000000 Hz 1.5 dBmV 33.8 dB 0 0 16 Locked QAM 256 31 585000000 Hz 1.9 dBmV 33.8 dB 0 1 17 Locked QAM 256 32 591000000 Hz 1.7 dBmV 33.8 dB 0 0 18 Locked QAM 256 33 597000000 Hz 1.7 dBmV 32.9 dB 0 0 19 Locked QAM 256 34 603000000 Hz 2.2 dBmV 33.3 dB 1 0 20 Locked QAM 256 35 609000000 Hz 2.2 dBmV 34.4 dB 0 0 21 Locked QAM 256 36 615000000 Hz 2.2 dBmV 34.3 dB 0 0 22 Locked QAM 256 37 621000000 Hz 2.7 dBmV 34.3 dB 0 0 23 Locked QAM 256 38 627000000 Hz 2.4 dBmV 33.9 dB 0 0 24 Locked QAM 256 39 633000000 Hz 2.7 dBmV 33.9 dB 0 0 25 Locked QAM 256 40 639000000 Hz 2.0 dBmV 33.9 dB 0 0 26 Locked QAM 256 41 645000000 Hz 2.2 dBmV 33.9 dB 0 0 27 Locked QAM 256 42 651000000 Hz 1.9 dBmV 33.5 dB 0 0 28 Locked QAM 256 43 657000000 Hz 1.7 dBmV 34.3 dB 0 0 29 Locked QAM 256 44 663000000 Hz 1.4 dBmV 34.0 dB 0 0 30 Locked QAM 256 45 669000000 Hz 1.5 dBmV 33.9 dB 0 0 31 Locked QAM 256 46 675000000 Hz 1.5 dBmV 33.8 dB 0 0 32 Locked QAM 256 47 681000000 Hz 2.0 dBmV 33.6 dB 10 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 16400000 Hz 35.8 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 22800000 Hz 36.5 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 36.5 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 35600000 Hz 36.5 dBmV 5 Locked ATDMA 5 1280 Ksym/sec 39600000 Hz 33.0 dBmV 6 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV - plemansOct 10, 2020Guru - Experienced User
Hows it working? Got your logs with that?
reason I ask is your snr is a boarderline and the upstream power seems a touch low.
But in some cases, that'll work fine so its more about how well its working and how the logs look.
