ldonahue
Oct 09, 2019Aspirant
CM700 Downstream Power Levels
Hello, I have a NETGEAR CM700, Firmware: V1.02.02. I have super slow internet speeds on Spectrum 200MB. My average speedtest is under 10MB. If I reboot the modem, speed tests are usually arou...
- Oct 10, 2019
Has the ISP checking signal and line quality up to the modem?
Be sure there are no coax cable line splitters in between the modem and ISP service box.
Be sure your using good quality RG6 coax cabling up to the modem.
Oct 10, 2019Guru - Experienced User
