Smiwy
Oct 12, 2020Aspirant
Cm700 ethernet disconnected but internet still connected
Hi, My cable modem (cm700) ethernet sometimes disconnects, where the bottom ethernet LED goes completely out, and the router it's connected to loses signal. The rest of the lights stay on for the m...
Oct 13, 2020Guru - Experienced User
do you have a screen snip of the cable connections page and the logs from the modem?
Do you have the modem directly connected to where the coax line enters the home?
Any splitters, attenuators, or amplifiers in line?
Smiwy
Oct 13, 2020Aspirant
I have attached a screen snip of the modem page. I have it connected with coax, and outside there are no splitters or amplifiers, but there is a coax to coax adapter outside installed by Comcast.
- plemansOct 14, 2020Guru - Experienced User
How frequently is it happening?
If its happening often enough, you could hardwire a pc/laptop into the modem and run it for that period of time. If the computer drops/has issues, then its the modem. Your signal looks good.
Do you also have the logs? the signal page is just a brief glimpse.
