Lothurr
Nov 22, 2022Aspirant
CM700 flashing Ethernet light
I’m having issues with my cm700 and connections to my ISP. My isp (mediacom) says they can see that the line is live to the house. Here’s where it gets odd. I unplug the co-ax and connect to the modem...
- Nov 23, 2022
the ISP did not provision the modem correctly 😐
Lothurr
Nov 23, 2022Aspirant
Good morning,
The ISP is checking it out today for the signal quality. they used good coax to the modem. I removed any amplifiers and splitters which still did it. no kinks or damages. did the modem power off for 1min (actually let it sit 5min to see if it helped dissipate the capacitor charge in the modem). will keep you posted, i will get the modem connection status and event log later today after work. the connection was saying in progress. and there was a CVA failure in the event log.
Lothurr
