Robert_Tompkins's avatar
Apr 05, 2020
CM700 high US/UnCorrectables
Hi all, I have been experiencing internet issues for the last 3 years at my home. I found that my US(Upstream) power (modem transmitting data to the ISP) was intermittently maxing out (I forget th...
  • FURRYe38's avatar
    Apr 05, 2020
    Have the ISP check the signal and line quality UP to the modem.
    Be sure there are not coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    FYI:
    http://www.badmodems.com
