Robert_Tompkins
Apr 05, 2020Tutor
CM700 high US/UnCorrectables
Hi all, I have been experiencing internet issues for the last 3 years at my home. I found that my US(Upstream) power (modem transmitting data to the ISP) was intermittently maxing out (I forget th...
- Apr 05, 2020
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.FYI:
Apr 08, 2020Guru - Experienced User
OK, I would have the ISP run the line check at aswell. Have them review the logs as well.
Hope fully you or they can find where the main issue is.
Robert_Tompkins
Apr 11, 2020Tutor
Hey FURRYe38,
I’m having a hard time deciding between:
attenuator/splitter or NO attenuator/splitter.
Could I get your opinion? Opinions from others are welcome as well.
The ‘attenuator’ is just a 2-way splitter (-3.5dBm) with only 1 used Output, I left the unused terminal OPEN. If you feel I should connect a 50/70 Ohm resistor between signal conductor and GND rather than leave it floating, let me know. This attenuator is connected at the drop.
Here are some details/stats.
NO ATTENUATION:
_________________________
Downstream:
My DS PWR Level for Channels 1-24 range from +2.4 to +3.5 dBmV.
SNR/MER Range = 41.4 to 43.1dB
The following stats are from 50 Hours of UpTime with ~3.85E9 UnErrored CodeWords/Channel:
Correctables range from 500-2500(as frequency increases, Correctables INCREASE)
UnCorrectables range from 400-600(as frequency increases, UnCorrectables DECREASE)
Upstream:
PWR Levels:
46.8 dBmV
47.0 dBmV
48.0 dBmV
48.0 dBmV
_____________________________________
WITH ATTENUATION:
Downstream:
My DS PWR Level for Channels 1-24 range from -0.8dBmV to +0.0dBmV.
SNR/MER Range = 42.0 to 43.5dBmV.
The following stats are from 18 Hours of UpTime with ~2.87E9 UnErrored CodeWords/Channel:
Correctables range from 13-378 (as frequency increases, Correctables INCREASE)
UnCorrectables range from 62-98 (seemingly no correlation with deltaFrequency)
Upstream:
PWR Levels:
49.8 dBmV
50.3 dBmV
51.3dBmV
51.3 dBmV
I would copy/paste my logs, but all I have are screenshots of the old log, split between 2 separate images.
I noticed that WITHOUT the -3.5dB drop, my DS levels were all ~ +3.5dBmV, so a 3.5dB drop here would be perfect to hit unity. But as I expected, installing the splitter brought my (Already borderline HIGH) US levels From ~47.5dBmV up to ~ 50dBmV. I vaguely remember reading specs for the CM1000 indicating it was capable of ~54dBmV. This may be standard for all Modems, but still.
So based on the trade-offs described above.. would I be better off WITH or WITHOUT the splitter? Thoughts? Concerns?
I’ve noticed no differences in Download/Upload speeds via Speedtest.net.
However, I just noticed that PingPlotter is currently showing some problems. Like an elevated Latency Floor referenced to when I first set up my CM1000. The Jitter directly following CM1000 setup was <5mS. Currently it is regularly jumping to 30mS, averaging around 10-15mS. I’m going to remove the splitter and try again right now to remove any possible changes caused by temperature/time/neighbor loading, etc. Still, thoughts?
NO ATTENUATION:
Downstream:
Upstream:
PWR Levels:
46.8 dBmV
47.0 dBmV
48.0 dBmV
48.0 dBmV
WITH ATTENUATION:
Downstream:
Upstream:
PWR Levels:
49.8 dBmV
50.3 dBmV
51.3dBmV
51.3 dBmV
- Robert_TompkinsApr 11, 2020TutorDisregard the PingPlotter stats I mentioned above.... I’m an idiot lol. I connected my laptop to the Ethernet cable connected to the TV. I left the WiFi Enabled, so those stats were via WiFi connection..
