Ted2022
Sep 11, 2022Aspirant
CM700 in and out connection issue
I have been having in and out connectivity issues lately. I have read some of the past postings but I'm not sure how I can solve it. Could someone please help me? I am very dim on internet connec...
Ted2022
Sep 15, 2022Aspirant
Thank you for your reply again!
I have arranged a technician to come this Saturday!
While waiting I still have connectivity issues and I see something new in the log.
Not sure what "Map Request Retry Timeout", "DHCP RENEW WARNING - Field invalid in response v4 option", "TEK Invalid - Invalid Key Sequence Number" mean.
(Not that I understand the others lol)
I never had such connectivity issues before since I moved in 4 years ago, so I am wondering why this is happening frequently only now...
| Sep 13 2022 06:48:45 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Sep 13 2022 16:49:42 | Critical (3) | No Ranging Response received - T3 time-out |
| Sep 14 2022 04:45:24 | Error (4) | Map Request Retry Timeout |
| Sep 14 2022 06:50:09 | Critical (3) | No Ranging Response received - T3 time-out |
| Sep 14 2022 09:05:24 | Error (4) | DHCP RENEW WARNING - Field invalid in response v4 option |
| Sep 14 2022 21:48:27 | Critical (3) | No Ranging Response received - T3 time-out |
| Sep 15 2022 01:29:25 | Warning (5) | TEK Invalid - Invalid Key Sequence Number |
| Sep 15 2022 03:22:23 | Critical (3) | No Ranging Response received - T3 time-out |
| Sep 15 2022 07:02:52 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Sep 15, 2022Guru - Experienced User
Those are all ISP related events that need to be reviewed by the ISP.
Also you could ask them if you can use one of there modems to see if the problem continues with there modem as well. Rule out a CM modem or ISP issue.
Let us know how it turns out.
- Ted2022Sep 15, 2022Aspirant
Thanks, and will do! I will provide an update once it's reviewed by a technician this weekend.
- FURRYe38Sep 15, 2022Guru - Experienced User
đ
- Ted2022Sep 22, 2022Aspirant
On 17th, a technician from WOW came and he replaced the cable in the yard to the service box on the exterior wall. He said the cable was old.
He didn't do anything on the cable from the service box to the modem, said there was no splitter and it was only a joint.
Now that the new cable is buried and the work is complete, I am still not sure if it resolved the issue, looking at the log below.
Does anyone see a sign of improvement after 17th?
As I was writing I am encountering very slow connection, but it is not recorded in the log..
Time Priority Description Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 11 2022 14:02:29 Critical (3) No Ranging Response received - T3 time-out Sep 12 2022 17:11:43 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option Sep 12 2022 18:25:26 Critical (3) No Ranging Response received - T3 time-out Sep 13 2022 06:48:45 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Sep 13 2022 16:49:42 Critical (3) No Ranging Response received - T3 time-out Sep 14 2022 04:45:24 Error (4) Map Request Retry Timeout Sep 14 2022 06:50:09 Critical (3) No Ranging Response received - T3 time-out Sep 14 2022 09:05:24 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option Sep 14 2022 21:48:27 Critical (3) No Ranging Response received - T3 time-out Sep 15 2022 01:29:25 Warning (5) TEK Invalid - Invalid Key Sequence Number Sep 15 2022 03:22:23 Critical (3) No Ranging Response received - T3 time-out Sep 15 2022 07:02:52 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Critical (3) No Ranging Response received - T3 time-out Sep 15 2022 07:22:34 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Sep 15 2022 12:32:11 Critical (3) No Ranging Response received - T3 time-out Sep 16 2022 06:47:07 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option Sep 16 2022 06:50:09 Critical (3) No Ranging Response received - T3 time-out Sep 17 2022 10:56:03 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Sep 17 2022 10:56:08 Warning (5) Lost MDD Timeout Sep 17 2022 10:56:09 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Sep 17 2022 11:10:12 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Sep 17 2022 11:16:59 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Sep 17 2022 11:17:01 Warning (5) Lost MDD Timeout Sep 17 2022 11:17:07 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Sep 17 2022 11:17:27 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Sep 17 2022 19:36:04 Critical (3) No Ranging Response received - T3 time-out Sep 18 2022 04:37:46 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option Time Not Established Critical (3) No Ranging Response received - T3 time-out Sep 18 2022 07:42:38 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Sep 18 2022 07:44:09 Error (4) Map Request Retry Timeout Sep 18 2022 14:29:58 Critical (3) No Ranging Response received - T3 time-out Sep 19 2022 13:44:50 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option Sep 19 2022 16:32:55 Critical (3) No Ranging Response received - T3 time-out Sep 20 2022 13:17:35 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Sep 20 2022 13:17:40 Warning (5) Lost MDD Timeout Sep 20 2022 13:17:42 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Sep 20 2022 13:18:51 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Sep 20 2022 14:11:54 Critical (3) No Ranging Response received - T3 time-out Sep 21 2022 13:31:51 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option Sep 21 2022 15:04:54 Critical (3) No Ranging Response received - T3 time-out
