ketchupmania
Nov 10, 2019Aspirant
CM700 Intermittent Pack Loss and High Latency
Over the past few weeks I've been experiencing intermittent packet loss or high latency when receiving packets. As a result, in games I get micro stutters and sometimes slingshot. Streaming videos is...
ketchupmania
Update: Checked the cable in the wall and it is an RG6 cable. I decided to try running my own spare cable from the garage to the modem (50ft RG6). Issues are still occurring. Here's the cable that I am using: https://www.amazon.com/AmazonBasics-CL2-Rated-Coaxial-TV-Cable/dp/B01DN7NRXS/
Here are the new levels from that cable:
Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables 1 Locked QAM 256 1 483000000 Hz 6.0 dBmV 40.9 dB 1 0 2 Locked QAM 256 2 489000000 Hz 5.9 dBmV 40.3 dB 11 0 3 Locked QAM 256 3 495000000 Hz 5.8 dBmV 40.3 dB 7 1 4 Locked QAM 256 4 507000000 Hz 5.8 dBmV 40.9 dB 0 0 5 Locked QAM 256 5 513000000 Hz 5.9 dBmV 40.3 dB 0 0 6 Locked QAM 256 6 519000000 Hz 5.5 dBmV 40.3 dB 0 0 7 Locked QAM 256 7 525000000 Hz 5.6 dBmV 40.3 dB 7 0 8 Locked QAM 256 8 531000000 Hz 5.8 dBmV 40.3 dB 829 0 9 Locked QAM 256 9 543000000 Hz 5.3 dBmV 40.9 dB 22 0 10 Locked QAM 256 10 549000000 Hz 5.0 dBmV 40.3 dB 1 0 11 Locked QAM 256 11 555000000 Hz 4.8 dBmV 40.3 dB 1 0 12 Locked QAM 256 12 561000000 Hz 5.0 dBmV 40.9 dB 0 0 13 Locked QAM 256 13 567000000 Hz 4.9 dBmV 40.3 dB 1 0 14 Locked QAM 256 14 573000000 Hz 5.0 dBmV 40.3 dB 1 0 15 Locked QAM 256 15 579000000 Hz 4.8 dBmV 40.3 dB 1 0 16 Locked QAM 256 16 585000000 Hz 4.6 dBmV 40.3 dB 1 0 17 Locked QAM 256 17 591000000 Hz 4.4 dBmV 40.3 dB 1 0 18 Locked QAM 256 18 597000000 Hz 4.1 dBmV 40.3 dB 1 0 19 Locked QAM 256 19 603000000 Hz 4.0 dBmV 40.3 dB 1 0 20 Locked QAM 256 20 609000000 Hz 4.0 dBmV 40.3 dB 1 0 21 Locked QAM 256 21 615000000 Hz 4.0 dBmV 40.3 dB 1 0 22 Locked QAM 256 22 621000000 Hz 3.9 dBmV 40.3 dB 0 0 23 Locked QAM 256 23 627000000 Hz 3.9 dBmV 38.9 dB 0 0 24 Locked QAM 256 24 633000000 Hz 3.7 dBmV 39.5 dB 1 0 25 Locked QAM 256 25 639000000 Hz 3.7 dBmV 38.9 dB 2 0 26 Locked QAM 256 26 645000000 Hz 3.7 dBmV 39.5 dB 2 0 27 Locked QAM 256 27 651000000 Hz 3.7 dBmV 39.5 dB 0 0 28 Locked QAM 256 28 657000000 Hz 3.5 dBmV 39.2 dB 0 0 29 Locked QAM 256 29 663000000 Hz 3.4 dBmV 38.9 dB 1 0 30 Locked QAM 256 30 669000000 Hz 3.0 dBmV 39.5 dB 1 0 31 Locked QAM 256 31 675000000 Hz 3.2 dBmV 38.9 dB 0 0 32 Locked QAM 256 32 681000000 Hz 3.0 dBmV 39.2 dB 0 0
Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 3 5120 Ksym/sec 17300000 Hz 34.5 dBmV 2 Locked ATDMA 4 5120 Ksym/sec 23700000 Hz 34.5 dBmV 3 Locked ATDMA 1 5120 Ksym/sec 30100000 Hz 34.5 dBmV 4 Locked ATDMA 2 5120 Ksym/sec 36500000 Hz 34.5 dBmV 5 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
