MustangHX
Aug 25, 2018Aspirant
CM700 keeps rebooting
My CM700 has random rebooting issues, happens about every 2 hours.
The power outlet is stable as I also use it to power my router.
Firmware version is 1.02.02, using COX premium
Any ideas?
MustangHX
Aug 26, 2018Aspirant
Just attached event log
vkdelta
Aug 27, 2018NETGEAR Employee Retired
Please attach the power/connection table from the GUI
- MustangHXSep 07, 2018Aspirant
Are these power/connection table you are refering to?
- vkdeltaSep 08, 2018NETGEAR Employee Retired
Most likely there is noise on one upstream channel causing T3 timeouts. Have you had this issue previously? or this a new install?
- MustangHXSep 08, 2018Aspirant
It's a new install. How do I solve this upstream issue? Which channel has more noise? Channel 1 or channel 4? Are these power figures (43.3 dbmv to 46.3 dbmv) within the operation range?
