MustangHX
Aug 25, 2018Aspirant
CM700 keeps rebooting
My CM700 has random rebooting issues, happens about every 2 hours.
The power outlet is stable as I also use it to power my router.
Firmware version is 1.02.02, using COX premium
Any ideas?
MustangHX
Sep 08, 2018Aspirant
It's a new install. How do I solve this upstream issue? Which channel has more noise? Channel 1 or channel 4? Are these power figures (43.3 dbmv to 46.3 dbmv) within the operation range?
vkdelta
Sep 08, 2018NETGEAR Employee Retired
I dont think you can solve unless it is inside home wiring issue. Most of the time problem is in outside node which needs ISP technician to fix it.
Upstream powers look good. Mid-40s is good range.
