Deedle28
Jan 29, 2020Aspirant
CM700 modem access log-in
I cannot gain access to my modem online. The userguide has http://192.168.100.1 but I cannot get access. It spins and spins, and then I get a message the page cannot be opened.
- Jan 30, 2020
What happens if you disconnect the CM modem from the coax cable, factory reset the modem and connect up 1 wired PC to the back of the modem leaving the coax disconnected. You should be able to access the modems web page at 192.168.100.1.
However there is no usage tracking features on CM modems. Just diagnostic information and signal logging.
Deedle28
Jan 30, 2020Aspirant
The modem in connected to a LInksys router. We have been using a lot more internet data than usual. Our internet is through comcast. They told me if I had one of their modems, I could use an app to see how much data my devices are using. I have my own modem, so they told me to contact Netgear. The owners manual said to enter the IP address. I'm thinking they thought I meant my router and not the modem. I have access to my router already, but I thought comcast said I could access the modem as well for more detailed information.
Jan 30, 2020Guru - Experienced User
