photosquirrel
Jul 21, 2019Aspirant
cm700 modem did not make the change when I upgraded to 400mbps charter
Hi, first post so be patient. Today I just upgraded charter internet speeds from 200mbps to 400mbps.. Upload took just fine I'm now getting around 21mbps from the 12 I had previously. However, downlo...
Jul 23, 2019Guru - Experienced User
Ask to see if there maybe any older FW that will help with the R series speeds.
PW = Password
Disable Access Controls as this may limit speeds as well. If you disable access controls, any device you connect will get internet access. Disabling Access Control only disables the entire feature on the router while you trouble shoot.
Good Luck.
photosquirrel
Jul 23, 2019Aspirant
Too funny, I thought PW meant password but was thinking it was something a bit more technical.. Thanks again for your help, at least now I know what the problem is most likely. Hopefully I can get it up to speed.
- FURRYe38Jul 24, 2019Guru - Experienced User
:smileywink:
