Logandhi
Dec 08, 2021Follower
CM700 Modem Internet Disconnects Every Day
I have been dealing with my internet disconnecting at least once a day for a few minutes which finally led me to my modem showing event logs that say "Unicast Ranging Received Abort Response - initia...
Dec 08, 2021Guru - Experienced User
You have errors in your line and your logs are indicating issues.
check your line for kinks, damage, old/bad/cheap/corroded/damaged connectors and replace them if you have them.
Remove any splitters, amplifiers, or signal attenuators from the line.
also, you can move the modem to right where the coax comes into the home to prevent the line in the home from being the issues.
If you still get the errors, then the ISP would need to check the line.
