Jdoog23
Feb 06, 2020Aspirant
CM700 Modem keeps dropping and speeds are super slow
As of the begining of this week my cable modem keeps dropping service and is having horrible speed problem. I have COX with the 300mbps plan and I am barely pulling 30mbps on a good day. I have looke...
Feb 06, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to test speeds directly connected to the modem with a wired LAN cable PC. Test with a different PC to compare results.
