jslickmurphy
Apr 13, 2020Follower
CM700 modem low download speed
Our ISP is claiming that our house is receiving the full 600 mbps speed, so they say it has to be our modem or router slowing things down. Our speed test show only 140 mbps on the 5.0 and 40 mbps on the 2.4 The modem says it can get up to 1.4 Gbps. Is there anything I can do in order to get the right speeds to my devices?
The CM modem doesn't have a built in router or wifi.
What are your wired speecs with a PC or laptop connected to the CM modem and not thru a router?
The CM modem is well capable of doing near 900Mpbs on wired speeds.
Refer to the wifi routers mfr support site for help and information regarding there wifi router.
Not all wifi devices will speed test out at anything over 400-500Mbps. Check with your wifi device mfr support site for help and information regarding there speed support.
jslickmurphy wrote:Our ISP is claiming that our house is receiving the full 600 mbps speed, so they say it has to be our modem or router slowing things down. Our speed test show only 140 mbps on the 5.0 and 40 mbps on the 2.4 The modem says it can get up to 1.4 Gbps. Is there anything I can do in order to get the right speeds to my devices?
- curtnorvalAspirant
Try changing the modem. Or contact your service provider to upgrade the service pack
Any progress on this?
