xcrmom
Sep 28, 2022Aspirant
CM700 Modem
Hello I have been told by my ISP that my modem is not working properly and that it needs to be replaced. Here are the specs: Can anyone recommend anything for me to try. My ISP just increased my i...
Sep 29, 2022Guru - Experienced User
Might try a different CM series modem then. CM1000, 1100, 1200 or 2000.
Kitsap
Sep 29, 2022Master
Your Belkin F9K1123v1 router design dates from 2014. In the technology world that is old and it will have a difficult time keeping up with modern cable internet throughput.
https://www.amazon.com/Belkin-AC1200-Wireless-Router-F9K1123/dp/B00JY4QCJQ
Recommend you also consider replacing the router.
