cjzjeeps
Nov 25, 2020Aspirant
CM700 No Ranging Response received
Power and download lights are solid, upload light is blinking, internet light is off. Cox is telling me it’s the modem.
cjzjeeps
Thank you. I do not know but will ask the ISP about provisioning.
There are no splitters in line. There is a booster, because without it the power is less than 1.0.
Nov 25, 2020Guru - Experienced User
Take the booster out.
acceptable power levels for downstream is -7.5dbmv to 7.5dbmv. So a 1.0 is pretty perfect.
- plemansNov 25, 2020Guru - Experienced User
and if there's issues with the line, a booster only makes them worse
- cjzjeepsNov 27, 2020Aspirant
Thank you plemans . Without the booster downstream power is between -1.0 and 1.0, SNR is ~38 and upstream power is ~57.
I got the modem to start working by doing a factory reset.
- plemansNov 27, 2020Guru - Experienced User
without the booster your downstream levels are perfect but your upstream is pretty high.
Do you have an extender coax run? or an attuator/slitters in the line somewhere? usually the upstream levels are based off what the cmts needs to get a signal. And with downstream being spot on, the upstream shouldn't need to be that high.
