pjs15
Apr 23, 2020Tutor
CM700, no wireless settings on login
Using a Windows 10 computer, using a browser via 192.168.100.1 to access Netgear Genie. INternet service is provided by Comcast.
Once I'm logged in, there is no option for changing the security settings. Under Advanced and Administration, my only options are Modem Status, Set Password, and Event Log.
This happens with Chrome, Internext Explorer, and Firefox.
What do I need to do to access the Security settings so I can make sure the modem is using advanced security features -- or is that something that Comcast handles and I have no access to?
Thanks for any tips.
The CM700 is a modem only.
There isn't wireles. It isn't a router and doesn't have routing capabilities.
- pjs15Tutor
Thanks, plemans. To quote Homer Simpson: "D'oh!" (hand slaps forehead) I was recalling what I used to see when logging into my Netgear router. Thanks for the reminder.
