roseexe's avatar
roseexe
Cm700 not connecting to internet
My modem randomly stopped working and DOESNT reset, do I have to buy another one?
  • plemans's avatar
    What are the led's on it doing?
    Are you able to hardwire into the modem directly from a pc/laptop (reboot the modem after connecting)?
    try accessing it using 192.168.100.1
    • roseexe's avatar
      roseexe
      The LEDS are all green, the power button is the only one solid the rest have been flashing constantly. plemans
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Mobile Routers, Hotspots & Modems. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Cable Modems & Routers
    These devices are very different from the Mobile Routers, Hotspots & Modems covered here.
