cm700user's avatar
cm700user
Follower
Mar 19, 2019
CM700 rebooting
Hello,
I am using CM700 for several months. In these days, CM700 keeps rebooting.
So, I am putting up the pictures of the cable connections.
Please verify that this is a problem of modem, or a problem of cable.
Thanks advanced.
These are the pictures when I lost connection.
These are the pictures that I have connection.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    The power levels look to be a little high they should be between 7 and -7 you may want to have a tech come check the lines.
    DarrenM
