raif281
May 26, 2020Follower
CM700, unplugged it for 10 minutes now it wont work
I have a cm700 which I've had for almost 2 years with no problems. Our new TV came in yesterday so I unplugged everything to rerun wires and straighten it up some. The modem was unplugged for maybe 10...
May 26, 2020Guru - Experienced User
If you log into the modem (192.168.100.1). What is the screen shot showing for the cable connection page?
did you add any splitters, attenuators, amplifiers to the line?
Change any connectors? maybe there was corrosion on one of the coax lines and removing caused an issue.
