Ghecko
Jul 01, 2020Aspirant
CM700 Wont Reach Close To 1Gb Speed
I have a CM700 Modem that worked flawlessly with my 300Mb plan through Sparklight/Cable One. I was actually getting about 350 Mb download speeds. I changed my plan to the 1Gb service after about 5 ...
Jul 02, 2020Guru - Experienced User
What speeds do you get hardwired into it?
What website/websites have you used for testing?
What device is the isp testing the speed with? its easy for them to say "sure, mine hits 1gig"
Do you have a screen snip of the cable connections page from the modem?
