Parkss0n
Feb 21, 2018Follower
CM700
Since November '17 the Ethernet LED has been flashing green non-stop and the network has become extremely slow and unstable in my house. What is causing this?
1 Reply
> [...] the Ethernet LED has been flashing green non-stop [...]
According to the CM700 User Manual:
Ethernet
o Green. A powered-on device is connected to the Ethernet
port at 1000 Mbps.
o Blinking green or amber. The Ethernet port is processing
traffic.
One interpretation of a flashing green Ethernet LED would be that the
device which is connected to that port (perhaps a router?) is sending or
receiving data through the CM700.
> [...] the network has become extremely slow and unstable in my house.
All I know about your network is that you have a CM700, which, I'd
guess, is not the source of the problem.
If some device on your LAN has gone berserk or has been hijacked,
then that could account for a flood of traffic, which might be
interfering with the traffic you care about. What are all your other
LED indicators indicating? Assuming that you have a router of some kind
connected to this CM700 port, can you get any information from it about
what it's doing?
Last ditch: Start shutting down or disconnecting your devices until
the problem traffic subsides.
