rosede
Oct 25, 2022Aspirant
CM7000 dropping connection. ISP say's time to replace modem
I have a four year old CM7000 modem, firmware version is v1.02.04. About a month ago, my ISP had a major outage in my area. I saw trucks outside of my neighborhood working on something and I was dow...
rosede
Nov 03, 2022Aspirant
I would like to following up on this issue. I had a technician out who provided a splitter with two attenuators, each with a different level of of power reduction. I am currently on the un-attenuated port of the splitter. This port is a -5.5db out. The attached file show's the current power levels and errors that I am still receiving. All of the power levels are now within tolerance, so I don't know if I want to try one of the other attenuators or not.
Please advice.
Thank you
Daryl
Nov 14, 2022Guru - Experienced User
You still have some Correct and Un-correctables. I'd be checking COAX cabling and fittings.
If looks good here, you may want to try a different modem in place to see if the problems continue or not. If you get another NG modem, you'll be able to see same pages for results.
